I know that internal usb 3.0 cables are a pain in the ass and can look bad because they are bulky and stiff.  The mobo I have is a sniper 5 from gigabyte and does not have a right-angle header.  I was wondering if anyone knows if you can buy a right angle adapter of some sort. I would pay money for something like that
https://linustechtips.com/topic/26696-right-angle-usb-30-cables/
You can get them. Found this one here, but it's not the actual product that you can pay for. http://image.made-in-china.com/2f0j00ksjazuFCHUqT/USB-3-0-Pin-Header-Right-Angles.jpg
Also, this may prove helpful for you. http://forum.overclock3d.net/showthread.php?t=45728
https://linustechtips.com/topic/26696-right-angle-usb-30-cables/#findComment-339156
I want something Like this I'm fed up of the ugly stiff USB 3 cable.
PC Builder, Engineer... BACON    Project Cobalt: http://linustechtips.com/main/topic/38058-project-cobalt-copper-piping-laser-etching-and-more/#entry489258
| NZXT Switch 810 | i5-3570k | gigabyte UD-5H | Corsair Vengeance 8gb ram | GTX 670 | 2x 60gb intel 330 series ssd's in raid 0 | 1tb seagate barracuda hdd | Corsair tx750m | XSPC razor GPU and CPU waterblocks | XSPC d5 vario pump | Thermochill Pa140.3 | phoyba 280mm radiator | Chromed Copper tubing |
https://linustechtips.com/topic/26696-right-angle-usb-30-cables/#findComment-340445
something like what? no pic link or drawing..
airdeano
something like the description in the OP.
https://linustechtips.com/topic/26696-right-angle-usb-30-cables/#findComment-341519
