PCI Wireless Adapter
Go to solution Solved by xox,
so my download speed is about 100 Mbps and upload about 70 and I want to get a pci express wireless or usb for my desktop without going over 30 bucks.
 You guys rule, thanks
Edit: Range shouldn't be a big deal because my ipad mini and MacBook can connect to school modem from my room.
Steam:Drift and Drift_2 <p>(name is hunter) Lets play:)
https://linustechtips.com/topic/266936-pci-wireless-adapter/
Compatible with Windows 95
https://linustechtips.com/topic/266936-pci-wireless-adapter/#findComment-3625957
ASUS USB-N13
is their a difference with 300 and 450 will it affect my speed a lot?
https://linustechtips.com/topic/266936-pci-wireless-adapter/#findComment-3626024
install dot vpn to chrome it removes all restrictions
Buy my yoga 2 pro!  http://linustechtips.com/main/classifieds/item/2711-lenovo-yoga-2-pro-i7-4510u-8gb-ram-4k-btc-accepted/
[spoiler=Trumps Wall
]AMD FX 8320 OC@ 4.4 GHZ GPUamd sapphire 7950RAM: 12GB CORSAIR XMS3 Psu: Corsair cx 500m CASE: Corsair 800d MOBO: Asrock 970 extreme 3 r2 Storage: 256GB mx100 SSD, 1TB WD Blue,1tb Seagate Barracuda in Raid 0, 750GB Seagate Baracude. Os Windows 7
CPU: AMD A-10 5800k RAM: 4GB DDR3 Storage:Random drives Mobo:msi SomthingCase: good question
https://linustechtips.com/topic/266936-pci-wireless-adapter/#findComment-3626086
Nope, not really. I'd go for the second one though because it's got a better chipset.
what do you think of asus n13 because usb is easier than having to fit wifi card with sli 770s sorry this computer
https://linustechtips.com/topic/266936-pci-wireless-adapter/#findComment-3626230
