Thank you soooo much , I'll report back soon. You are a blessing
         cout << "Users Guess" << "\t\t\t" << "Generated Cards" << endl;    for (int i = 0; i < 5; ++i) {        // Get the names of the choices from the deck        std::string UserChoice = CARDS;       std::string GeneratedCard = CARDS;        // print the names side by side        cout << UserChoice << "\t\t\t" <<GeneratedCards<< endl;    }
Am I on the right track?  I am getting a weird error here, I can only input two pointers.
Or
std::string UserChoice = GetGuess();       std::string GeneratedCard = GenerateCorrectCards;
Hmm
https://linustechtips.com/topic/266389-function-help-c/page/2/#findComment-3630274
OOH dear lord I swear i did that and it gave me an error haha is it strange to say I love you lollllll  It did generate nothing like you said and is also only giving me the user input, my brain is so numb from staring at this code for days straight... so should i decrement cards *(deck + i - 1) in main like you suggested?
https://linustechtips.com/topic/266389-function-help-c/page/2/#findComment-3630935
OOH dear lord I swear i did that and it gave me an error haha is it strange to say I love you lollllll  It did generate nothing like you said... so should i decrement cards *(deck + i - 1) in main like you suggested?
That's not quite right. Using *(CARDS + i) is only going to give you the first 5 members of the array. You need to use something else instead of i
Remember, you need to match the contents of the other arrays to the strings in CARDS.
https://linustechtips.com/topic/266389-function-help-c/page/2/#findComment-3630962
void DisplayCards (int *user, int *generatedCards)        {                                                 cout << "Users Guess" << "\t\t\t" << "Generated Cards" << endl;             cout<<"***************************************************"<<endl;    for (int i = 0; i < 5; ++i) {        // Get the names of the choices from the deck        std::string UserChoice = (*(CARDS+i));       std::string GeneratedCard = (*(generatedCards+i));        // print the names side by side        cout << UserChoice<< "\t\t\t" <<GeneratedCard<< endl;    }
And I get the error  [Error] invalid conversion from 'int' to 'const char*' [-fpermissive]
for generated cards
https://linustechtips.com/topic/266389-function-help-c/page/2/#findComment-3630975
So, something like
  std::string UserChoice = (*(CARDS+user));
Edit:You must hate me man lol I'm basically a toddler with c++ I'm asking the stupidest questions.
Haha don't worry.
You're really close with that one. Remember, user points to the first value of the array but it wont change when i is increased.
https://linustechtips.com/topic/266389-function-help-c/page/2/#findComment-3631032
std::string UserChoice = (*(CARDS)+(*(user));
       std::string GeneratedCard = (*(CARDS)+(*(generatedCards));
I think this is what you mean?
But I am getting the error    [Error] no match for 'operator+' in '*(std::string*)(& CARDS) + * user'
https://linustechtips.com/topic/266389-function-help-c/page/2/#findComment-3631143
You're very close. Here's what you need.
*(CARDS + *(user + i))// *(user + i) will be familiar to you since you've used it so much// You're using that to get the value out of user in each loop.// Example// if *(user + 3) contains the value 4// Then what we are doing is getting the value in *(CARDS + 4) (ie: blue circle)
Hope you understand.
https://linustechtips.com/topic/266389-function-help-c/page/2/#findComment-3631215
I do not :( I have until 11:58 to turn this in. Madknight if you finish this block for me I will design you the sickest avi or signature or both ever.   After that I get this error
        // get the names of the choices from the deck
        std::string UserChoice = *(CARDS + *(user + i));
       std::string GeneratedCard = *(CARDS)+*(generatedCards+i));
  [Error] no match for 'operator+' in '*(std::string*)(& CARDS) + *(generatedCards + ((sizetype)(((long long unsigned int)i) * 4ull)))'
https://linustechtips.com/topic/266389-function-help-c/page/2/#findComment-3631229
Is this correct?
  std::string UserChoice = (*(CARDS) + (*(user + i));
       std::string GeneratedCard = (*(CARDS)+(*(generatedCards+i));
I'm getting this:
Error] no match for 'operator+' in '*(std::string*)(& CARDS) + *(user + ((sizetype)(((long long unsigned int)i) * 4ull)))'
https://linustechtips.com/topic/266389-function-help-c/page/2/#findComment-3631292
Lmao really? Gahd...
Thats what I have now and either way I have them I get the same unfortunate error... ooh lord.. 4 minutes
https://linustechtips.com/topic/266389-function-help-c/page/2/#findComment-3631329
