I really want a new monitor as my primary and my Dell as a secondary. The Dell and monitor I want have cheap $20 VESA mount adapters since they don't come with them. They simply just screw where the original monitor stand would go
Anyway, the mount, I want something cheap and able to rotate the screens easily. One screen will be 27", and I'm still unsure if I just want a monitor mount for a main then one off to the left, or just the secondary monitor above.
I really want to get the stand as cheap as possible as I really do not have much to spend. Thanks! :D
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
https://linustechtips.com/topic/266339-dual-display-mount/
Dell makes dual monitor stands as long as your monitors are under 24" I think. I'm not sure whether you can buy them separately tho.
Edit: this the one I'm talking about - http://www.amazon.co.uk/DELL-482-10011-DUAL-MONITOR-STAND/dp/B00EAM2D0O/ref=sr_1_2?ie=UTF8&qid=1418065253&sr=8-2&keywords=dell+dual+monitor+stand
Dreadnaught: Intel Core i7 970 3.2GHz, Silverstone TD-02, ASUS Rampage III Extreme, Kingston Fury White 24GB 1866MHz, Crucial BX100 250GB + Seagate 2TB SSHD, AMD Radeon Sapphire R9 390 Nitro, NZXT S340 White, Bitfenix Fury 650W, BenQ XL2730Z.
https://linustechtips.com/topic/266339-dual-display-mount/#findComment-3618557
http://shop.easymountlcd.com/main.sc
They even sell open box for real cheap. Better to get it from them then over paying with amazon.
https://linustechtips.com/topic/266339-dual-display-mount/#findComment-3622742
