Need help with planning
Go to solution Solved by andre82693,
AX
So I just received my MSI gtx 970 yesterday and of course I didn't realise quite how long it is and then with my luck my PSU blew up.
This means I need to upgrade *sarcastic yay*.
I have an i5 3570k, gtx 970, 8gb ddr3, 1 hdd, 1 ssd, gigabyte GA-Z77-D3H in my build.
What PSU would you recommend? (I had a Tesla 750te-br before) Should I go fully modular?
Which case would you recommend? (Has to fit the GTX 970 comfortably, I also didn't realize it's quite a wide card).
Preferably I would want to go much over £200 for the two.
Thanks for any advice and I'm sorry if this isn't the correct section :D
https://linustechtips.com/topic/266187-need-help-with-planning/
You had a 750W PSU and it blew up with those specs?!?
Current rig: CPU: AMD FX-8120  Cooling: Corsair H100i  Mobo: ASRock 970 Extreme 3  RAM: 8GB 1333Mhz  GPU: MSI GTX 660Ti Power Edition  Case: Fractal Design Define R4  Storage: 2TB Seagate HDD + 128GB Crucial SSD  PSU: be quiet! 730W bronze
https://linustechtips.com/topic/266187-need-help-with-planning/#findComment-3616426
Those PSU look good, I was also looking at the RM 750w PSU, quick question, whats the difference between the digital and standard?
I was looking at this case, opinions? http://www.corsair.com/en/graphite-series-730t-full-tower-case for £74.
https://linustechtips.com/topic/266187-need-help-with-planning/#findComment-3616497
good case
https://linustechtips.com/topic/266187-need-help-with-planning/#findComment-3616551
I had an optical drive in my previous case and was interested in keeping I and that's why I stepped away from the h440. Also my system colour scheme is red and black.
Corsair Graphite 760T PC Computer Case - YouTube
Edited by andre82693
https://linustechtips.com/topic/266187-need-help-with-planning/#findComment-3616630
I'm just stuck between the 450d and the 730t by corsair atm, they're both roughly the same price.
Looking at this PSU but wondering if it's worth £25 more than it's RM little brother.
http://www.amazon.co.uk/Corsair-Professional-Series-Modular-Platinum/dp/B00A74X9SO/ref=sr_1_1?ie=UTF8&qid=1418052806&sr=8-1&keywords=corsair+ax
https://linustechtips.com/topic/266187-need-help-with-planning/#findComment-3617115
