I recently build myself a new PC [specs: Intel i7 2600, asus maximus iv extreme, msi lightning r7970, kingston hyperX 1600mhz 2x4 gb ramkit, ocz fatality campion 1000w psu] Everytime I start my PC everything seems to work, but I don't get a post "beep" and nothing shows up on my screen! The only thing I noticed is the debug LED shows the number 60 meaning "DXE core is started". But after restarting a couple of times, the system boots normaly and everything seems to be working fine.
And sugestions?
Thanks.
https://linustechtips.com/topic/26554-debug-led-60-error/
Had a look around and some folks had found that their RAM caused this type of error. You might want to remove a stick and boot with just the one, see if it helps. If you get a good POST and the OS loads, try it again with both sticks.
Your best effort is the easiest thing to give to someone else..
https://linustechtips.com/topic/26554-debug-led-60-error/#findComment-338939
I tried with only one stick, but same problem. :(
https://linustechtips.com/topic/26554-debug-led-60-error/#findComment-340183
