I considering overclocking my graphics card (Asus Gtx 970 Strix) and I had some questions.
1. Is is safe to keep your overclock on at all times?
2. What offset should I start with?
3. How do I know when to stop turning up my Core clock and my Memory clock?
I hope my questions were clear enough. Thanks in advance! :D
https://linustechtips.com/topic/265111-overclocking-graphics-card-questions/
Max out power limit
Use 1400/7800 or something in that region as a starting point.
Use Unigine Valley or Unigine heavy to test, if the OC is unstable then the following can occur: artifacting, freezing followed by driver crash/pc crash, clocks tanking, bluescreen
This won't harm your GPU and as long as the OC is stable and the temps are low enough then it's safe for 24/7. Normal bioses can't up the voltage far enough to be hazardous for 24/7
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
Max out power limit
Do you recommend any overclocking software?
MSI afterburner, EVGA precision X
I prefer precision X because of Kboost. With Kboost it does not downclock/undervolt but it prevents crashing in smite and other games (My card keeps switching between low performance and medium performance in that game causing driver crashes).
Thanks for the help!
One more question, when you say 1400 does that mean boost clock?
1400 core clock on boost
7800 memory clock on boost
So that's in situations like gaming/valley.
