Guys, Im facing this weird csgo problem where I'm not able to find any comp matches. It takes me 20min Minimum to get single match.... and i can find casual matches in like 1min max(mostly 20sec).....  cant understand whats the problem Im facing here... Coz people from my region who are in my friend list can get matches in 1/2mins max and if i queue up with them then they also start facing the problem i"m facing. have kept my ping to max(which is 350).
[CPU: AMD FX(tm)-4350 @4.2GHz ] [MoBo: 970 PRO GAMING/AURA] [Ram: 2x8GB HyperX FURY 8GB 1600MHz DDR3] [GPU: NVIDIA GeForce GTX 1060 6GB] [PSU: Corsair VS550Watt] [HDD: 2TB Seagate Barracuda + 1TB WD green] [CPU Cooler: JONSBO CPU AIR COOLER - CR-201 RED LED] [Display: LG 24MP88HV-S 24-inch Slim IPS] -Did i solve your question/problem? Please click 'Marked Solved'-
https://linustechtips.com/topic/264808-weird-csgo-problem/
The time depends on many factors, from rank, how many players online (with ranks around the same as your rank).
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/264808-weird-csgo-problem/#findComment-3600989
first of all this issue was not there till last month....  my friends from same region can get matches easily.... and I'm silver 2(coz im a dota 2 player not csgo :3) but this left apart i don't understand y i don't get matches when i can get casual matches easily....
https://linustechtips.com/topic/264808-weird-csgo-problem/#findComment-3601007
Rank?
Silver 2
https://linustechtips.com/topic/264808-weird-csgo-problem/#findComment-3601013
You get into casual ranks easily because it just matchmakes with anyone, it doesn't account for rank.
https://linustechtips.com/topic/264808-weird-csgo-problem/#findComment-3601017
but i was silver 2 last month also... i never faced and issue then.... but y now...
https://linustechtips.com/topic/264808-weird-csgo-problem/#findComment-3601034
Not sure, I get into games within 2 minutes and I'm Nova 1.
https://linustechtips.com/topic/264808-weird-csgo-problem/#findComment-3601038
