Location?
Peripherals, OS or Monitor inside of the build?
I7 4790K • Corsair H110 • MSI Z97 SLI Krait Edition • Kingston Fury Hyper X (White)(16GB)(1866Mhz) • Crucial MX 100 512 GB • Seagate Barracuda 1TB • Phantek Enthoo Pro • EVGA G2 750 Watt
Asus DRW Optical Drive • TP Link Wifi Adapter • Asus MX279H • CM Devastator Bundle (Blue) • Bitfenix Spectre Pro (White) • Windows 8.1
Galax Hall Of Fame 970
https://linustechtips.com/topic/264444-need-help-with-a-build/#findComment-3596676
In need Windows 8.1 no monitor and US
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($71.98 @ Newegg)
Video Card: Diamond Radeon R9 280X 3GB Video Card  ($199.99 @ Newegg)
Case: NZXT S340 (White) ATX Mid Tower Case  ($59.99 @ Micro Center)
Power Supply: Corsair Builder 500W 80+ Bronze Certified ATX Power Supply  ($44.99 @ Micro Center)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($89.98 @ OutletPC)
Total: $669.68
Generated by PCPartPicker 2014-12-05 15:47 EST-0500
You can change a few things in here, like the CPU to Intel G3258 and overclock the cpu if you are up for it. As it is though, I can't say whether dual core will be enough for the new games, but this would be able to play most for sure.
https://linustechtips.com/topic/264444-need-help-with-a-build/#findComment-3596737
Total: $669.68
why not the pentium aniversery ?
https://linustechtips.com/topic/264444-need-help-with-a-build/#findComment-3596755
I did mention it in my post. the only reason why I didn't add it cause I wasn't sure if he wanted to overclock as well, so I told him the option below the part list
https://linustechtips.com/topic/264444-need-help-with-a-build/#findComment-3596783
oh lol
https://linustechtips.com/topic/264444-need-help-with-a-build/#findComment-3596786
