No HDMI audio
Solved by failblox,
Try getting the display driver for integrated graphics from your motherboard's website.
I don't use Windows Update for installing drivers... it always installs really old drivers that were outdated months ago. It's better to download them manually.
Also - don't use the disk that's bundled with your motherboard, because those drivers are usually outdated by a few months as well.
Edit: actually before doing all that, why don't you check if the audio device is even detected by looking under 'audio devices' (or something along those lines)
