You should get a psu with more watts like 650 watts. 450 does not leave you with much room to upgrade. especially if your going to do overclocking
[CPU] i7 4790K OC [CPU Cooler] H100i [GPU] Evga GTX 980 SuperClocked [Ram] Corsair Vengeance 16 GB 1866 mhz [PSU] Cooler Master 1000w Silent Pro [storage] 256 GB Samsung 840 Pro, 1TB Seagate SSHD, 1 TB WD Blue 4 TB Seagate Nas. [Motherboard] Msi Z97 Gaming 5 [Case] Phantom 410 Red [sound] Onboard ALC 1150 [Headphones] Sennheiser HD 558 [Keyboard] Razer BlackWidow Chroma  [Mouse] Razer Deathadder Chroma [Mouse] Razer FireFly [Monitor] Asus MG278Q
https://linustechtips.com/topic/263929-my-build-plan-thoughts/#findComment-3589565
Looks nice. You need to make sure that all of this fits inside of the case. If the extra money is avaliable, then I would go for the GTX 980 for the more performance, and there isn't much of a difference in prices.
Depending on what you will be using the system for, you might want a bigger SSD and a little bit more RAM, as sometimes when recording my videos, I tend to get high on RAM with my games taking up so much (I have 8GBs)
I am a Tech Enthusiast; Gamer, Computing student; Small YouTuber and a keyboard warrior :^)
System Specs:
CPU: AMD FX-9590 8Cores@4.7GHz (5GHzBoost) | RAM: 16GB (Mixed Kingston&Corsair) | GPU: ZOTAC GTX 960 4GB | Case: Bitfenix Merx Alpha | Storage: Samsung 850 EVO 120GB [BOOT]; 240GB OCZ SSD [Games] ;1TB SSHD | PSU: 800W something | Displays: AOC 24" 1080p 16:9; Yuraku 19" monitor | Cooling: Noctua NH-D15 | Keyboard: Razer Blackwidow 2014 Tournament Edition [Green Switches] | Mouse: Razer Deathadder 2013 | Mouse Pad: Razer Vespula | Audio: Razer Tiamat 2.2+ Razer Hammerheads Pro | Operating System: Windows 10 Home
https://linustechtips.com/topic/263929-my-build-plan-thoughts/#findComment-3589575
A GTX 980 is a lot more money than a GTX 970.
https://linustechtips.com/topic/263929-my-build-plan-thoughts/#findComment-3589604
true, it just depends on what you are doing and how many monitors you wish to run on your setup.
I currently run 2 with my GT 620 but as I hope to upgrade to a GTX 770, I would like to keep my current and use both to host 3 or 4 monitors with my old GPU running the extra monitors and my new GPU running my middle gaming monitor, as all my monitors vary in size.
System Specs:
https://linustechtips.com/topic/263929-my-build-plan-thoughts/#findComment-3589611
Well i don't intend on running more than 3 ever really.. I'm currently only running two monitors which the 970 will support fine. I might mount a 47 inch tv above them just for fun, but that is about it.
https://linustechtips.com/topic/263929-my-build-plan-thoughts/#findComment-3594690
