Is it worth it or the speedlink controller is better?? Whats the average use time with rechargable batteries?(2450MaH). Any opinions?
CPU: AMD FX 8350 | GPU: AMD R9 270 Windforce | MOBO: ASRock 990FX Extreme 3 | RAM: Kingston HyperX 8GB | Case: X Predator X1 |CPU COOLER: Hyper T4
NAZIS WILL RISE.
https://linustechtips.com/topic/263779-x360-wireless-controller-on-pc/
i got 2600ma batteries and I charge them once a month with heavy use or once every 2 months with regular 2 hour daily use and yes wireless is worth it
Does it work with all the games? Are the buttons remapable? Does it work with pirated games?
NAZIS WILL RISE.
answer to all of them is "It depends on the game"
“Advertising has us chasing cars and clothes. working jobs we hate, so we can buy shit we dont need.”- Chuck Palahniuk, Fight Club
"Oh, beauty is a beguiling call to death and I'm addicted to the sweet pitch of its siren."- Johnny Quid
"Without our imaginations, we'd be like all those other poor... dullards."- Dr. Hannibal Lecter
And theres no lock to steam or what ever (you can play pirated games?).
That list is basicly all the best games.
" XInput mainly appears with games made for both Windows and the Xbox 360 console " - when ms drops support for x360 will the controller for the newest games work? ... probably not but theres still some time.
NAZIS WILL RISE.
Yes it should work on pirated games without a hitch.
We can only hope that controller support will be continued, but even if it isn't supported you can download third party software and manually map the buttons.
Games that support controllers at all will work with the XBox 360 controller. It may require keybinding or may just pick it up and go but it will work. As for when the 360 is phased out, from what I understand, the XBox One controller on Windows uses the same Xinput API that the 360 one does so there shouldn't be an issue.
