Advise for Math
Guest Philosophy
I was asked to help come up with some basic geometry sample problems with answers and show how they are done. I would like to know if this seems like a good one and if my math is correct. Thanks! I don't want to look like an idiot.  Is there anything you'd do different or change?
https://linustechtips.com/topic/263522-advise-for-math/
Yep it's all correct, except the first line of working where there are two equals signs (same in first line of check) but that is obviously a typo. If you are teaching this to someone you should probably add more context to the problem (like a painter sets up a ladder blah blah blah) just to make it more engaging and also be sure to mention that pythag theorem is appropriate in this situation because and ONLY because there is a right angle at the wall (otherwise you wouldn't be able to use it). Other than that, solid effort  :D  :D  :D
Lorem ipsum dolor sit amet, consectetur adipiscing elit. Quisque euismod suscipit est, non placerat turpis vestibulum sed. Phasellus et faucibus odio. Donec a nisi at purus porttitor ullamcorper auctor a nibh. Integer id neque a nisi laoreet ultrices id ac augue. Nulla facilisi. Nullam purus elit, dictum quis euismod vitae, mollis non dui. Morbi vehicula neque eu mattis bibendum. Curabitur sed odio tortor. Sed euismod mi in diam volutpat, vitae convallis ipsum mattis. Praesent eleifend faucibus pulvinar. Interdum et malesuada fames ac ante ipsum primis in faucibus. Vestibulum velit nunc, fermentum a libero a, venenatis tempus lectus.
https://linustechtips.com/topic/263522-advise-for-math/#findComment-3584344
I have a good friend whos kids who are home schooled. They are younger and just getting into geometry. She cannot do math and I am fairly decent.
you should check out khan academy free and super great for math
https://linustechtips.com/topic/263522-advise-for-math/#findComment-3584348
Isn't there a thing with Pythagoras' theorem that if you're calculating the length of a shorter side you have to throw everything you know out the window and do it differently?
CPU: i7 2600 @ 4.2GHz  COOLING: NZXT Kraken X31 RAM: 4x2GB Corsair XMS3 @ 1600MHz MOBO: Gigabyte Z68-UD3-XP GPU: XFX R9 280X Double Dissipation SSD #1: 120GB OCZ Vertex 2  SSD #2: 240GB Corsair Force 3 HDD #1: 1TB Seagate Barracuda 7200RPM PSU: Silverstone Strider Plus 600W CASE: NZXT H230
CPU: Intel Core 2 Quad Q9550 @ 2.83GHz COOLING: Cooler Master Eclipse RAM: 4x1GB Corsair XMS2 @ 800MHz MOBO: XFX nForce 780i 3-Way SLi GPU: 2x ASUS GTX 560 DirectCU in SLi HDD #1: 1TB Seagate Barracuda 7200RPM PSU: TBA CASE: Antec 300
https://linustechtips.com/topic/263522-advise-for-math/#findComment-3584370
needs more calculus
That'll get their brains warmed up
I done been through a whole lot. Trial, tribulations, but I know God - Kendrick Lamar
I question your mother's upbringing if you don't like me - Action Bronson
You apocalyptic dingleberry - James 'Captain Slow' May
https://linustechtips.com/topic/263522-advise-for-math/#findComment-3584371
Nope. Just rearrange the formula. lol
https://linustechtips.com/topic/263522-advise-for-math/#findComment-3584442
needs more calculus
Omg please don't. I just failed my calc finals because I forgot my indefinite integrals... :(
Specifically all this:
“The value of a college education is not the learning of many facts but the training of the mind to think”
https://linustechtips.com/topic/263522-advise-for-math/#findComment-3584455
If I added more context and added what not would this be a good one also? and is everything correct. My brain is fried after a days work. I haven't done geo since high School. @Mujteba @T.Vengeance
I think you should because it is a bit plain, but really depends on the students and how well they learn which is something only you can assess. Also you are putting equals signs where there should be plus signs like second line.
Also x+w =/ 180.... that's not correct geometry (The angles aren't on opposite sides of the same line.... that's a circle theorem you are thinking of  :)  )
For this you should start by: Sum of angles in a triangle is 180degrees. So from there we can work out w by
w+95+29=180
w=180-95-29
w=56
Also x can be found separately x+29=180 (it's a straight line right)
x=180-29
x=151
as you can see w+x= 151+56
w+x=207 which is not 180
https://linustechtips.com/topic/263522-advise-for-math/#findComment-3584462
I haven't done geometry for a few months, I forget stuff way too easily too
https://linustechtips.com/topic/263522-advise-for-math/#findComment-3584502
