i took off my stock cpu cooler and put it back on to fix cable management ( before it was routed around the cooler)
i made the rig about 4 days ago
i used the same thermal paste and dint reapply anything!
will this affect anything?
im getting same temps
yes, you should reapply every time you take it off.
Having problems with your fresh Windows 10 install? PM Me!
Windows 10- Want To Disable Telemetry, Disable Cortana, Disable Windows Updates? Look at my guide HERE
LTT Beginners Guide  | Community Standards | TN&R Posting Guidelines
https://linustechtips.com/topic/262784-thermal-paste-help/#findComment-3575242
if you did it quickly you should be fine, ya it's recommended but I wouldn't sweat it
// irenebb-pc v5 // [] Intel i5-9400F [] Radeon VII Lisa Su Edition [] 24GB Crucial Ballistix [] Acer ED323QUR (1440p/144hz) []
https://linustechtips.com/topic/262784-thermal-paste-help/#findComment-3575249
