lag problems
Go to solution Solved by Deserter15,
I would upgrade cpu first or at least overclock it.  You have the same setup i have but I have a 660 rather than the 650ti boost and the cpu on mine continues to max out.
When i play a high class game like far cry 4 or bf4 i lag every now and then i ccant tell if im bottle capping or my gpu is just bad, what do i need to upgrade first?
Specs
Processor : AMD FX-4130 @ 3.8 ghz
RAM : 8.00GB Dual-Channel DDR3 @ 534MHz
Graphics : 1023MB NVIDIA GeForce GTX 650 Ti BOOST
https://linustechtips.com/topic/262542-lag-problems/
As soon as you said that i thought i pulled up after burn and watched the usages and both were capped out when i put them to ultra so i need both first thanks man
https://linustechtips.com/topic/262542-lag-problems/#findComment-3572458
