when I booted up my computer there was a CPU FAN ERROR  so I checked in bios and the RPM speed is written in red (200rpm)  but the cpu temp is 30-35 degrees should I worry? and as the temp is increasing the rpm is also increasing
Beneath this mask there is an idea, and ideas are bulletproof.
https://linustechtips.com/topic/262383-cpu-fan-error/
means the Fan isnt spinning fast enough i think? i had that and set the minimum to run at 400RPM
GPU: EVGA GeForce GTX 980 4GB Superclocked ACX 2.0 @1500mhz + 8000Mhz CPU: Intel Core i7 6700k Delided and Overclocked @4.8  MB: ASUS MAXIMUS VIII IMPACT  RAM: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory CPU Cooler: Corsair HG10+ H90 +H90 CASE: Corsair 380T  Storage: 120GB Samsung Evo SSD + Crucail 256GB Mx100 + 2TB Seagate/  OS: Windows 10 64bit Power supply:  Corsair RM750
https://linustechtips.com/topic/262383-cpu-fan-error/#findComment-3570932
What cooler? Usually an error pops up when the fan speed gets too low. You can set an option to ignore it
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
https://linustechtips.com/topic/262383-cpu-fan-error/#findComment-3570934
If you are using an ASUS motherboard, it's a known issue.  I get that too sometimes but a restart usually fixes it.  It's a BIOS issue.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/262383-cpu-fan-error/#findComment-3571094
I am using asus , my motherboard want him to be at a minium of 300 RPM  but fan is like nah not doing that bro . but when its getting hotter the rpm also increases so Ill just set bios to ignore errors then.
https://linustechtips.com/topic/262383-cpu-fan-error/#findComment-3571171
