Hi guys,
I'm new to PC gaming and would like to build a decent gaming machine for <$2000.
I have done SOME research, but am feeling super overwhelmed with trying to pick the right components in order to get a good experience.
This is what I have come up with so far: http://ca.pcpartpicker.com/p/3FTjLk
Any comments and/or suggestions?
(I'm also wondering if this CPU cooler will physically fit in the case with all the other components since it does look relatively large.)
Thanks for any input!
-E
(ps, if this is posted in the wrong sub-forum please give me a heads up!)
https://linustechtips.com/topic/261688-first-build-help-hardware/
i am sorry but i have to say it you should just get windows 8.1
if you don't like the windows start screen just use classic shell from https://ninite.com/
Project Iridium:   CPU: Intel 4820K   CPU Cooler: Custom Loop  Motherboard: Asus Rampage IV Black Edition   RAM: Avexir Blitz  Storage: Samsung 840 EVO 250GB SSD and Seagate Barracuda 3TB HDD   GPU: Asus 780 6GB Strix   Case: IN WIN 909   PSU: Corsair RM1000      Project Iridium build log http://linustechtips.com/main/topic/451088-project-iridium-build-log/
I would recommend ditching the i5-3570k and going with a newer i5-4690k.  Then you can get rid of the z77 board and get you a z97 board.  There are a lot more of the z97 boards to choose from right now.
I would also recommend using Windows 8.1 over Windows 7.  I just upgraded when I went to a 4k display and I am much happier with Windows 8.1.
Noctua makes some pretty killer CPU coolers too.  They're pricey but an excellent option especially if you are purchasing one of those Noctua fans for the CPU cooler you selected.
there is a section called " new builds and planning ".....this should be there.....this is not a guide nor a tutorial
CPU: i7 4790k OC'd @ 4.6 ghz COOLER: Corsair H105 (SP 120mm Quiet Edition Fans) MOBO: ASRock Z97 Extreme 6 RAM: Kingston Hyper Fury 16GB (2x8) 1866mhz
SSD: Samsung 840 EVO 250GB HDD: WD Blue 1TB GPU: EVGA GTX 970 FTW 4GB PSU: EVGA Supernova G2 750w 80+ Gold Fully Modular CASE: Fractal Arc Midi R2
OPTICAL DRIVE: Samsung DVD Burner OS: Win 7 64bit   Please do some research of your own before asking questions. Google and Youtube are your friend.
