But make sure you have USB 3
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
https://linustechtips.com/topic/261248-ethernet-over-usb/#findComment-3559578
When you plug your adapter in make sure it's drivers have installed correctly. Do this by going in to device manager and looking for any yellow warning icons.
To connect two computers togeather you have to use a cross over Ethernet cable for it to work.
If you want to know if your cable is cross over or not look at the colours in the plug.
Cross over will have on one end.
Orange stripe orange. Starting on the left finishing on brown on the right.
And on the other end of the cable it should start green stripe green.
https://linustechtips.com/topic/261248-ethernet-over-usb/#findComment-3563476
Im not asking about cat5/6 cables, im talking solely a USB connection to have the ethernet protocol running over it.
So what your saying is you solely want to connect two pc's togeather over one usb cable and then transfer ip data over it..? I think the best answer is you can't.
Why do you want to do this?
Why can't you just connect them via a Ethernet cable?
https://linustechtips.com/topic/261248-ethernet-over-usb/#findComment-3575587
Perhaps it would be best to describe what you would like to achieve, instead of asking for possibility with one scenario.
As moody said, it is not possible. It has something to do with motherboards expecting to HOST devices, not be a device itself. The closest single-cable would be the Laplink USB cable, but even that is only proprietarily used for transferring files between two computers, and not about sending network packets between the two. The closest to what you describe at this time is to have two USB network adapters and a network to hook up between the two.
CPU AMD 7800X3D | Cooling Noctua NH-D15 chromax.black | Motherboard ASUS PRIME X870-P WIFI | RAM Corsair Vengeance RGB 6GHz CL30 32GB | GPU EVGA GeForce RTX 3070 FTW3 Ultra Gaming |
Case Fractal Design Define R5 | Storage Samsung 980 PRO 500GB, Samsung 970 EVO+ "v2" 2TB | PSU Corsair RM850x 2021 | Display ASUS VP247QG + Samsung SyncMaster T220 | OS CachyOS
https://linustechtips.com/topic/261248-ethernet-over-usb/#findComment-3575904
Having looked at the wiki article, I have to point out that (emphasis mine):
There are many low-cost commercial adapters available to do this.
which, to me, sounds like you cannot just find any regular USB-A to USB-A cable, connect the two computers together and expect it to work. You need to get a cable that is dedicated to this exact purpose.
https://linustechtips.com/topic/261248-ethernet-over-usb/#findComment-3584315
Here's a link to the "usbnet" driver you mentioned: http://www.linux-usb.org/usbnet/. Of note, it explains the regular USB-A to USB-A cables and why it does not work:
Yes, you may occasionally see "A-to-A" cables for sale; don't waste your money buying them. Those cables are forbidden in USB, since the electrical connections don't make any sense at all. (If you try to use one, you might even short out your USB electronics and so need to buy a new system.) Basically, they're missing the extra electronics shown above, which is necessary to let a USB "master" (host) talk to another one, by making both talk through a USB "slave" (device). (There is one time you may need such cables: when you're working with a hardware development system where the single USB port can be configured - for development only! - in either master or slave roles.)
That last part about hardware development system is not something one can easily reconfigure on consumer products, because, hey, it even says: "for development only!"
So, if you still insist on this mission to run a network over USB, I will have to repeat my previous assessment: You need to get a specialized cable.
https://linustechtips.com/topic/261248-ethernet-over-usb/#findComment-3587746
