Hi all! :D
I was just wondering about what other people get as far as temps go.
FX-4300
Clcokspeed: 4407 MHz
Voltage: 1.3250
Temp idle: N/A
Temp full load (AIDA 64): 32 C
Cooler: Zalman Quiet CPU cooler
CPU fan: DATECH 2.50 Amp 19v fan 300 CFM!
Btw, that fan sounds like a jet engine at full rpm.
https://linustechtips.com/topic/260618-fx-4300-temps/
Hi all! :D
FX-4300
Voltage: 1.3250
Temp idle: N/A
It really depends on the ambient temp and what you are using to measure the temp. The integrated sensor(is not really a sensor) and gives false reading 99% of the time, which is why people post such low temps(yet have so much heat coming out of the machine).
Oh, and When I turned my FX-6300 to a 4300(by disabling 2 cores) I was getting roughly 40c at idle and 48 with load(ambient around 25c). My cpu cooler is the BTF90 by ZEROTherm
https://linustechtips.com/topic/260618-fx-4300-temps/#findComment-3552170
