OS Not installing from USB
Go to solution Solved by MeltingPoint,
What OS? I recommend you use Rufus to make a bootable drive.
Set the file table to 'GPT for UEFi based computers' and file format to 'FAT32'
Tick all boxes expect for the top one.
Evening guys
So i just built a new PC everything is working fine accept i cant i install the OS and it just keeps going straight to the UEFI Bios.
Yes i know i could plug in an optical drive but that would be to easy!!!
The drives and USB stick is being detected
So
Motherboard Asus Maximus VII Formula (Latest drivers)
Stuff i have tried
  • Latests BIOS Drivers
  • Changing the USB stick to FAT32 File type
  • Boot priority's are correct, as in the USB stick is the primary boot device
I know there are alot of videos and information out there but i just still cant get it working.
If anyone's got any advice i would be very grateful
Screenshots are below
Thanks guys
post-51813-0-04701400-1417278391_thumb.j
post-51813-0-57982700-1417278417_thumb.j
post-51813-0-94502400-1417278422_thumb.p
"Guardianship of all living things lies with those whose evolution is most complete. The Mantle of Responsibility shelters all."
https://linustechtips.com/topic/260223-os-not-installing-from-usb/
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
Ok trying now.
What am i using for the ISO image? changing it?
I understand that if this was a download i'd select.
Select the ISO file of the installer. If you have a physical disk, you can use an image creation tool to make an ISO from the disk. Use something like PowerISO but find one that is free
60FPS Microwave
I just downloaded an the ISO file straight from Microsoft, just waiting for Rufus to finish
http://answers.microsoft.com/en-us/windows/forum/windows_7-windows_install/windows-7-home-premium-64bit-iso-download/709dcc12-d120-435d-91cd-52e1dd0f4c24
So did it work? I had to sleep btw
60FPS Microwave
