Need help with building a computer
Solved by Interfectorem,
Depends what you want out of your gaming experience, I assume this is for gaming? I'd prefer a 750ti in your situation. Not a fan of AMD's heat output and power consumption
The R9 270 isn't a 290X Mine gets to 66C max while playing BF4, and only 1 6-Pin isn't much power consumption.
Hello. I am planning to build a computer and I am in need of assistance. This is the current build I plan on getting http://pcpartpicker.com/p/KT27ZL. Would an R9 270(non x) be better? An ASUS R9270 ($149.99) is $20 more than the 750ti ($129.99) on Amazon. Is the better performance worth the $20?
I would rather go with the R9 270, as it performs much better and it's a very nice card overall for gaming. I own one and I recommend it.
