so here's the thing:
i got tired of waiting for the OTA update for my nexus 7 2013 edition and i decided to install the OTA myself via ADB and command line, everything was going well to the point where i just had to put the last command "adb sideload [OTA UPDATE].zip, but at some point in the process my computer stopped recognicing my tablet (on the beggining it did and i used some commands) so when i imput the command it says it cant find the device.
Now i just decided to pull back and cancell it but i'm stuck at a no command screen. Does anybody know what can i do to get back? Help please
The best way to measure the quality of a piece of code is "Oh F*** "s per line
https://linustechtips.com/topic/258930-help-on-nexus-7/
First off welcome to the forum.
Plug your phones SD into your computer media reader> formant it for android> put the .ZIP on there> Let you phone die> put in SD> Plug In> Open .zip> Retry
Obligatory PC specs
CPU: Intel Core i5-6600K 3.5GHz
CPU Cooler: Corsair H50
Motherboard: Asus Z170-E ATX LGA1151
Memory: G.Skill Ripjaws 4 Series 16GB (2 x 8GB)
Storage: ADATA Premier SP550 240GB
Storage: Western Digital Blue 500GB
Storage: Western Digital BLACK SERIES 1TB
Video Card: Gigabyte GeForce GTX 1060 6GB 6GB G1
Case: Fractal Design Define S
Power Supply: Corsair CSM 550W
If you are new please read the CoC!
 Please FOLLOW YOUR OWN THREADS!
 Quote people when replying to them.
PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR DARK THEME USERS.
 Mark your problem as solved if answered and like all helpful information.
 DO NOT QUOTE IMAGES(!) just type -pic- or tag them as spoiler.
Don't criticize people for asking "stupid question".
There is actually a hidden search feature on the forums here: Search
IT DOESN'T MATTER IF YOU'RE A FANBOY/FANGIRL. WHAT MATTERS IS THAT YOU DON'T LET THAT EFFECT YOUR HARDWARE RECOMMENDATIONS.
DO NOT POST SPAM!
https://linustechtips.com/topic/258930-help-on-nexus-7/#findComment-3536004
im pretty sure the nexus 7 doesnt have an SD card
try plugging it in, in boot loader mode and see if ADB recognizes it. then just continue the install from there
https://linustechtips.com/topic/258930-help-on-nexus-7/#findComment-3536034
try plugging it in, in boot loader mode and see if ADB recognizes it. then just continure the install from there
it's windows that says there's no drivers and when i point the drivers it says it cannot find the drivers in that folder
https://linustechtips.com/topic/258930-help-on-nexus-7/#findComment-3536044
it has no SD
Yes it does, look up a video on its location.  After you let it die and try again let me know the results
Obligatory PC specs
DO NOT POST SPAM!
https://linustechtips.com/topic/258930-help-on-nexus-7/#findComment-3536058
No... it doesn't.
http://www.androidcentral.com/why-nexus-devices-have-no-sd-card
Eien nante naito iikitte shimattar  /  Amarinimo sabishikute setsunai deshou
Dare mo ga hontou wa shinjitai kedo  /  Uragirarere ba fukaku kizu tsuite shimau mono
https://linustechtips.com/topic/258930-help-on-nexus-7/#findComment-3536127
I'm back with my update,
I let tye tablet die and thankfully when i charged it back it was working normally again. I dont think i will be trying to update myself soon.
Just for the record, while reading somewhere else, i found out that there's actually a known issue between android USB drivers and windows 8, so be carefull if you try to do what i did
Thank you everyone for your help
https://linustechtips.com/topic/258930-help-on-nexus-7/#findComment-3538821
If you have a big USB (like 16 Gb) install windows 7 and put the .zip on there, boot from the USB and try again.
Obligatory PC specs
DO NOT POST SPAM!
https://linustechtips.com/topic/258930-help-on-nexus-7/#findComment-3541693
That's weird. My older nexus 7 2012 got android 5.0 a while back.
It sucks balls. Too slow. I have to disable background tasks in dev options.
I had that problem with mine, a factory reset fixed it completely and now it's blazing fast :) give it a try!
sudo chmod -R 000 /*
https://linustechtips.com/topic/258930-help-on-nexus-7/#findComment-3541783
Yeah I kinda just rolled all my apps over with the updates. Going to try reinstalling them after I'm done with the restore. Thanks for the advice.
Play the greatest game ever. TF2. http://www.teamfortress.com/
https://linustechtips.com/topic/258930-help-on-nexus-7/#findComment-3542330
