2.1 Preamp/Receiver Help
Go to solution Solved by ShearMe,
You wont find one. Power amps only have raw wire connectors or banana plugs if they are fancy. However, you could always get adapter cables -> http://www.amazon.com/Rockford-Fosgate-RFI2SW-Speaker-Adapter/dp/B009B8EJYU/ref=sr_1_1?ie=UTF8&qid=1417128779&sr=8-1&keywords=rca+to+bare+wire
Hey,
I'm looking for a 2.1 sound system preamp/receiver that outputs left, right, and bass RCA. I have looked all over for one, but cannot find one.
Suggestions are 100% welcome
Thanks
Intel i5 6600k~Asus Maximus VIII Hero~G.Skill Ripjaws 4 Series 8GB DDR4-3200 CL-16~Sapphire Radeon R9 Fury Tri-X~Phanteks Enthoo Pro M~Sandisk Extreme Pro 480GB~SeaSonic Snow Silent 750~BenQ XL2730Z QHD 144Hz FreeSync~Cooler Master Seidon 240M~Varmilo VA87M (Cherry MX Brown)~Corsair Vengeance M95~Oppo PM-3~Windows 10 Pro~http://pcpartpicker.com/p/ynmBnQ
https://linustechtips.com/topic/258927-21-preampreceiver-help/
I thought so... There were a million audio and video recievers.
This subwoofer has an RCA connector. While I've successfully split a 3.5 mm jack into right and left, there is obviously no subwoofer line. What should I do? Some suggestions have said I could split the right or left line and use that for the subwoofer.
I currently have it set up as a 5.1 system, but there are no back left or back right.
https://linustechtips.com/topic/258927-21-preampreceiver-help/#findComment-3536252
How about you explain in detail every component you have, down to model number if possible.  I don't wanna have to explain every scenario if your problem is super easy to fix.  ;)
https://linustechtips.com/topic/258927-21-preampreceiver-help/#findComment-3536596
The sound card I have is a Sound Blaster X-Fi Xtreme Audio sound card.
The speakers system is a Microlab H-200, product page here. I think it's a chinese company... Anyways, there is a manual that showcases what I'm working with. The "Pre-Amplifier" has broke and has been disposed of. The only things we have of the system now is the sub woofer (labeled HW-650), the left and right speakers, and the appropriate cords.
Currently, a 3.5mm to RCA L and R is running from the Sound Blaster's front left and right output to the sub woofer's L and R input. I also have a 3.5mm to RCA L and R running from the Sound Blaster's sub and front middle to the sub woofer's sub input. It isn't very elegant, especially considering it's running as if it were a 5.1 speaker system.
https://linustechtips.com/topic/258927-21-preampreceiver-help/#findComment-3560732
  • 3 weeks later...
@ShearMe
I've gone ahead and got one of those adapter cables. I understand what you were saying.
https://linustechtips.com/topic/258927-21-preampreceiver-help/#findComment-3710939
@ShearMe
OIC. Sorry for not responding to your previous post.
I'm not sure which channel of the center/sub output has a low pass on it - you'll have to test them to see which sounds better.
https://linustechtips.com/topic/258927-21-preampreceiver-help/#findComment-3711839
No problem, things get lost often.
I ended up moving the system to our living room. So I'm going to use the high level to rca adapter.
I honestly don't know if content would be lost if you ran the soundcard in 5.1 but only used a 2.1 system. My initial reaction would be yes as two of the speakers aren't there, but as I've said I don't know.
https://linustechtips.com/topic/258927-21-preampreceiver-help/#findComment-3733860
