What CPU would work best with...
Go to solution Solved by Clyne,
Right now I feel as if the best choice would be the AMD FX 9590, it's the highest rated CPU I could find that fit within my price range and would be a huge increase in performance. I'm not confident that this is the best decision, so I would appreciate some help. Thanks!
NO
A 9590 will kill your 970 motherboard immediately and it's not worth it. Just get a i5 4690K+Z97 board.
So I am currently in the process of upgrading my PC part by part. I have already upgraded my gtx 650 to a gtx 970, and I am planning on upgrading my CPU next, so I could use some help in making a decision.
Budget - $300 (I can go a little bit over if necesssary)
Current specs:
gtx 970
amd fx 6100
asrock 970 Extreme4
(Let's go on the assumption that my power supply will be adequate)
https://linustechtips.com/topic/258840-what-cpu-would-work-best-with/
I destroy my enemies when I make them my friends.
~Abraham Lincoln
In times when we are on the brink of destruction, war, and loosing ourselves, let's remember a basic fundamental element of love, forgiveness, and understanding; God bless!
NO
NO
^ This. You NEED a 990 chipset to run a 9590.. Just go with an i5 4690k.
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
