I am building a gaming focused PC with a budget of $1000-$1200 AUD including monitor and windows 8.1, if anyone could give some advice that would be great.
what do you want to use it for?
EDIT: didnt see the gaming part sorry
Its when dragons have so much sex that the cpu cant handle it
https://linustechtips.com/topic/258449-need-help-with-a-build/#findComment-3530988
