I currently have a Sapphire Radeon HD 7950 in my system, and, considering that age of this card, I am considering purchasing another with the same style cooler. The issue I have is my motherboard is micro ATX, so if I have 2 cards, they will be right next to each other (no slot in-between). How bad would the heat be if I were to run 2 cards? I realize that this spacing is not optimal, but would it be doable?
Thank you for your help.
https://linustechtips.com/topic/258194-crossfire-heat/
I've run two of those side by side no space. Runs fine. Yeah your room might get a little hotter. But otherwise not an issue.
Please quote/tag ( Found by typing @DarrenP) In all posts directed at me. I do not check my current content.
Intel Core i7-4790K - Gigabyte Z97X-UD5H-BK - 16GB Corsair Vengeance Pro 1866Mhz - EVGA GTX 980 - 256GB MX100 - 2TB WD RED - 900D - H100I - Corsair HX1050 - DNS 320L 2x2TB Seagate Barracuda
https://linustechtips.com/topic/258194-crossfire-heat/#findComment-3528514
I have a similar sli set up. I have a case fan on my side panel keeping them cool. However they still throttle at full load while gaming.
CPU: Intel i7 4770k 4.3ghz MOBO: Asus Z87 Sabertooth RAM: 2x8GB RipJaws 1866mhz GPU: 2x GTX780ti SLI 1.2ghz SSD: 960GB 2x Intel 730 RAID0 CASE: Fractal Design Define S COOLING: Custom EK watercooling loop
https://linustechtips.com/topic/258194-crossfire-heat/#findComment-3529757
