Hi Guys, I'm doing my first system build and just wanted to check if my components were the best chose.
I'm building this for 3 reasons.
1 to play GTA 5 when it comes out.
2 to torrent files.
3 content consumption, I plan to use it as a media pc as well.
Any kind of changes and recomendations are welcomed as i'd love to know were I can improve the system. As I am at my budget of $2500. Oh and I live in NZ so thats why prices suck.
CPU: Intel Devil's Canyon Core i5 4690K - $319.95
Motherboard: Gigabyte GA-Z97MX-Gaming 5 - $239.95
RAM: Corsair Vengeance Pro 8GB (2x4GB) DDR3-1866 - $169.95
GPU: ASUS STRIX-GTX970-DC2OC-4GD5 GeForce GTX970 4GB GDDR5 PCI-E3.0 - $669.95
Storage: Samsung 840 EVO Series 250GB - $189.95
Storage 2: WD Green 4TB - $219.95
Cooling: Corsair Hydro Series H100i - $219.95
PSU: CoolerMaster V550S 550W Modular Power Supply 80PLUS Gold - $139.95
Case: Corsair Carbide Series Air 240 High Airflow Cube Case - Black - $149.95
Wifi: ASUS PCE-AC68 802.11ac Dual Band Wireless-AC1900 - $159.95
Total ...... $2,479.50
Oh and if you can't guess its a black and red colour scheme  :P  :P  :P
https://linustechtips.com/topic/257832-first-system-build-the-black-devil/
2 to torrent files.
Why do you need wifi? Kinda doesn't add up with the torrent stuff, imo.
My setup: i5 3570K  - Corsair H100i - MSI Z77 GD65 - 256 GB Samsung 840 pro SSD - Corsair AX760i - Gigabyte GTX 670 Windforce 2GB - 4x4 GB Crucial Ballistix Tactical Tracer RAM - Corsair Carbide 500R (modded side window)
Maybe LAN's. That;s the only reason I have one is in case I forget an Ethernet cable and go to a LAN party
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
Well, I to go to LAN's, but I mean how many times will you forget to pack a ethernet cable, when you are already packing all of the rest of your cables for the LAN. Personally I can't see how you could forget such a thing, but might just be me
I forget one every now and then, also a friend may forget a ethernet cable so I'll sacrifice my cable I brought for them
2 to torrent files.
nice price you got there in new zeeland :)
maybe you want to look at the ssd MX100 256GB from crucial if its available
2 to torrent files.
For a cheaper budget I managed to squeeze in a i7-4790k and a GTX980. I'd drop the Wifi, get the H440 instead of the Air 540, Get a 3TB WD Green drive (dirt cheap) and replace the H100i with a H105.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
Wifi card is due to its expected location, no Ethernet available. AC wifi is pretty good these days anyway.
I was thinking of that drive too but it's only $10 difference :(
Man you're lucky!!! I7 would cost me $160 more. H440 $70 more. 3TB isn't enough storage and the H105 costs $10 more too. :(
Is there any cheaper or better motherboards out there? And is there any air coolers that have better performance for an OC 4690k vs an h100i?
Thanks
H440 retails at $99 while the Air 540 retails at $129, how does that work? And tbh the H105 is worth it - my H100i as well as a few other forum user's H100i's have had leaking / broken pump issues.
I have the Air 240 :) (Nz prices are shit too)
I was thinking about getting the H105. It clean and has those color accents which will tidy up the build
