HELP ME
Go to solution Solved by airdeano,
AX360 is a radiator with a fancy ally frame built around it (removable) 40mm thick
EX360 like the AX, but no shroud with similar fin array (very tight) 36mm thick
RX360 (V1 & v2) sub 10 fins per inch (loose) and 60mm thick
RX360 v3 now 13 fpi and 56mm thick
using the RX360 v1/v2 is difficult as most motherboard 8-pin EPS connection will
interfere with the radiator/fan. the v3 version might get some clearance, but doubtful.
the alphacool XT45 360 is a marvelous radiator. thin enough to fit and loose fin
array (low speed fans) and pretty much the beast for cooling.
https://linustechtips.com/topic/257663-help-me/#findComment-3523153
