7970 Reference Temperatures
Solved by RobertVanGilder,
FIX: The second monitor was the problem. When I took out the cable that connects to the second monitor, the card temps drop almost 20 degrees (They are now around 45).
Thanks everyone for your help
Playgb2 ·
Posted in Troubleshooting1 -
1
1
5
kasdashd ·
2
6
Ishikudeska ·
Posted in New Builds and Planning2 -
play_circle_filled
Latest From ShortCircuit:
