Hey lads,
I have $3000 (including a $50 shipping fee) to put together a X99 system. I plan to use this machine for intensive use on Unity, Photoshop, Blendr and some gaming here and there. My current monitor is the Asus MX299 which I will be keeping for this system. I have parts already selected via an Australian vendor (I live in Australia, Queensland).
Any kind of changes and recomendations are welcomed as i'd love to know were I can improve the system. I am ordering it in exactly 48 hours.
http://www.pccasegear.com/sc/Vh
Cheers, Suffokation.
The parts have been ordered! Cheers lads.
| Intel i7 5820K @ 4.8GHz | G.Skill Ripjaws 4X4GB | X99 PRO | HoF 980 | Asus MX299Q | Sennheiser HD600 |
https://linustechtips.com/topic/257484-3000-x99-build-help/
Better power supply
http://www.pccasegear.com/index.php?main_page=product_info&cPath=15_1619&products_id=27992
The GTX 970 is the way to go imo. They are way better value when you look at the performance difference between the two. You get maybe 15% more performance with a 980, but you are paying about 50% or so more.
You could drop the WD Black for a Seagate, although the Black is pretty good in a workstation type build.
https://linustechtips.com/topic/257484-3000-x99-build-help/#findComment-3521359
Better power supply
Thanks! That power supply is great! I might keep the 980 to be honest, I don't mind capping the budget. Unless there is something else in the build I can put more money into.
https://linustechtips.com/topic/257484-3000-x99-build-help/#findComment-3521380
Yeah the EVGA is one of the best psu's on the market for the price/performance.
Here is an alternative case that will give you better airflow. The H440 is a nice case but it is a bit restrictive due to the front panel design.
http://www.pccasegear.com/index.php?main_page=product_info&cPath=25_1573&products_id=28284
There is also a Black version as the White one is showing as 19/12/2014.
http://www.pccasegear.com/index.php?main_page=product_info&cPath=25_1573&products_id=27575
I know that cases are a personal thing, so if you like the H440 then it will still work fine.
https://linustechtips.com/topic/257484-3000-x99-build-help/#findComment-3521468
It's a good build but those are really expensive prices. They don't have deals in Australia? I built my x99 rig with monitor and m & kb for 2/3rds your cost.
Only change I would make is get a better brand SSD and a non SC 980 because you can save a few bucks and either way you will end up manually overclocking it.
PSU is fine but those prices...omg. I got an EVGA G2 750W Gold for 90 dollars after rebate.
https://linustechtips.com/topic/257484-3000-x99-build-help/#findComment-3523005
