by booting twice do you mean the pc seems to post twice before posting fully?
my ud3 did that too. i don't think it's anything wrong. i remember reading something about loading the correct settings for ram and cpu etc before posting.
i7-4790k | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | MX100 256gb     | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 White
G3258    | Asus Z97i-Plus     | Kingston HyperX Fury 16gb | 4 x 3TB WD Reds | Seidon 120XL | Silverstone SFX 600w Gold | Node 304 Black
i7-965EE | Rampage II Extreme | Kingston HyperX Fury 16gb | CM M2 700w | Sapphire Nitro 380 4GB
https://linustechtips.com/topic/257154-990fxa-ud3-memory-issue/#findComment-3517391
Yeah, the pc will turn on for a second then off again before it'll fully boot to windows. What are the settings? I think I tried everything I could think of. :(
https://linustechtips.com/topic/257154-990fxa-ud3-memory-issue/#findComment-3517399
i don't have that mobo anymore, but i remember that the turning on and off is to check the voltage/speeds of the ram/cpu if i'm not wrong.
it does that to prevent harming the components if the bios settings are wrong.
i don't think you need to worry about the turning on and off thing.
https://linustechtips.com/topic/257154-990fxa-ud3-memory-issue/#findComment-3517552
Okay so having to turn the PC on twice is okay?
https://linustechtips.com/topic/257154-990fxa-ud3-memory-issue/#findComment-3517662
yes. the particular board has that as a feature.
if it posts properly after the 2nd shut off it should be fine.
https://linustechtips.com/topic/257154-990fxa-ud3-memory-issue/#findComment-3517715
