I am trying to create a nas with ubuntu server. I am following a guide but not quite sure what to do.
Set Static IP Address
sudo nano /etc/network/interfaces
iface eth0 inet static
address 192.168.1.100
network 192.168.1.0
netmask 255.255.255.0
broadcast 192.168.1.255
gateway 192.168.1.1
dns-nameservers 192.168.1.1 8.8.8.8
Adjust the IP addresses for your network.
8.8.8.8 is Google DNS Server, I find this a lot better than my ISP’s DNS Server.
Add NAS IP Address to your Local DNS Lookup
This is on any Linux computer that you would like to access the NAS from.
sudo echo "192.168.1.100 nas.local" >> /etc/hosts
The NAS can be accessed via SSH with the following terminal command:
ssh user@nas.local
Install MDADM RAID Controller (Optional if using RAID)
sudo apt-get --no-install-recommends install mdadm
https://linustechtips.com/topic/254903-nas-help/
