Will my system bottleneck a 970 ?
Go to solution Solved by H4X3R,
No bottlenecks :)
So guys i'm about to build a Gaming/Soft Editing PC for around 1000€
Will the system (mainly the cpu) bottleneck the gtx970 ?
A must (http://www.chiptec.net/)
Rig:
CORE COMPONENTS
CPU 259,90€ - Intel Xeon E3-1240 V3
Motherboard 86,90€ - ASRock H97 Pro4 Intel H97 SK1150
Graphics Card 362,90€ - Gigabyte GTX970 WindForce OC 4GB GDDR5 PCI-E
Storage HD 51,90€ - Seagate Barracuda 1TB SATAIII 64MB (6GB/S)
SSD 68,90€ - Crucial MX100 2.5 Sata III 128GB
RAM 78,90€ - G.Skill ARES DDR3 2x4GB 1600MHz CAS9 1.5v
Power Supply 58,50€ - XFX TS 550W 80 PLUS BRONZE (P1-550S-XXB9)
Case 45,90€ - Zalman R1 - Black
Total 1013,8€
https://linustechtips.com/topic/254372-will-my-system-bottleneck-a-970/
Do you need a Xeon?
afaik thats a cheap I7 without IGPU and overclocking, which H97 cant do anyways
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
Do you need a Xeon?
I was going for an i7-4790 with a worst GPU but then everybody told me to get a xeon (cause I was already using a dedicated GPU and didn't need the int.graphics and i won't OC) and to get a better GPU
Ok
What are the planned uses?
Because he had a hard drive.
No OCing
i said that
That was wise advice. For those unfamiliar with this particular Xeon SKU, it's basically just a cheaper Core i7-4770/4790, sans integrated graphics. Don't let the Xeon branding throw ya off.
Don't worry a bit about a CPU bottleneck. That's a very powerful CPU.
