So when I use my Deathadder 2013 version while playing CS:GO, it stops tracking for about half a second to a second.
The only time I notice it is when I'm holding down mouse 1 (while trying to control the spray) it will freeze, and then when i let go, it starts tracking normal again.  The mouse 1 button still works this whole time, but I can't move my crosshair.
It doesn't happen very often, but it's annoying as it obviously gets me killed in game.
I've tried updating firmware/drivers and resetting the mouse (holding down mouse 1/2/3 for 5 seconds).
Is this a problem that is fixable? of should I try RMA? (I've heard bad things about Razer returns/refunds)
https://linustechtips.com/topic/253969-deathadder-2013-problem/
RMA. Might be some sensor problem.
My Current PC Codename: Scrapper
Intel i5-3570 | Some LGA 1155 MOBO Some Generic DDR3 8GB 1600Mhz | PowerColor RX 560 2GB | Recycled HP Case Crucial MX100 128GB 1TB WD Blue 7200RPM | Some Generic 500w PSU | Intel Stock Cooler
https://linustechtips.com/topic/253969-deathadder-2013-problem/#findComment-3479160
Well I bought a g502 to see if it was a mouse problem or something else, and I'm getting the same problem.
Currently I'm trying my usb 3.0 port to see if it is a usb problem or not (since I've already tried different usb 2.0 ports).  I've also tried reinstalling cs:go to no avail.
Does anyone have any ideas what else I could do to try to find the problem?
https://linustechtips.com/topic/253969-deathadder-2013-problem/#findComment-3490189
