Im planning for this build in about 2 months, But then again I do wonder when the GTX 960 comes out.
Anyways I'd love to see opinions, Ill make it in 2 sections. One will be bought at first time, second will be my future upgrade plans.
I also have a question, Is it possible to match a Dual Channel 8GB set (CL8 1600) With a 2nd Dual channel 16GB set, and if yes also if the CL and speed is diffrent?
I will be gaming but everything on ultra is not a must, will also be doing some video editing, graphics and programming. Something I will spend most my time doing is watching series and movies but that doesnt really matter. I'm currently coming from an i5-2410M + GT 520MX and for some reason my CPU is running at a 95c at all times. (Only do some slight counterstrike so far it goes to gaming) while I had an AMD A8-4500 APU with 7640G + 7470M 1GB Dual graphics on my other laptop. So the performance increase should be very big.
(I do not plan to overclock)
I'm currently using 120GB of my 240GB SSD which is the reason why I wont get an HDD till later.
Starting Build: (I Already have a SSD I can use, but will get another one for my laptop)
CPU: Intel i5-4690
GPU: MSI Geforce GTX 760 2GB Gaming (Or GTX 960 if its out in time)
Motherboard: MSI Z87-G43
RAM: G.Skill F3-1600C7D-16GTX (CL7 1600 16GB)
Case: Cooler Master CM 690 III Window
PSU: EVGA SuperNOVA 650 G1 Fully Modular
Wifi Card: Intel Dual Band Wireless-AC 7260 Plus Bluetooth (Yes this is a must)
IPS Monitor: AOC I2360PHU
Keyboard: Trust Classicline Keyboard
Total Price: 1055
Upgrade Plans:
HDD: Seagate Barracuda 1TB
CPU Cooler: - (Undecided, probably Cooler Master Hyper TX3 Evo)
4x 140mm Case fan(s): BitFenix Spectre Blue Led, 140mm
1x 120mm Case fan: Cooler Master Sickleflow Blue, 120mm
Mouse: CM Storm Mizar
Mechanical Keyboard: Corsair Vengeance K70 Black, Cherry MX Brown
Headset: HyperX Cloud
Mouse pad: CM Storm Speed RX Mousepad large
2nd RAM: G.Skill F3-1600C7D-16GTX (CL7 1600 16GB)
SSD: Kingston SSDNow V300 240GB
https://linustechtips.com/topic/253833-my-first-build/
