HELP! Nexus 5 Downgrade
Solved by iKiWY,
FIXED IT:
unpluged the device for an hour and used it in the middle, installed apps etc.
after that plugged in the device in the PC, put it into bootloader mode, changed the Android Bootloader Interface (in Device Utility) to Android ADB Interface and the back to Android Bootloader Interface, run the flash-all.bat and it worked!
l3eyond ·
1
Serendipity1344 ·
Posted in Graphics Cards4 -
1
1
5
1
toxic_worper ·
Posted in New Builds and Planning9
