Non-Reference cards with Reference look?
Solved by 79wjd,
so Club3D or Gigabyte R9 290 with reference look any good?
Don't buy a card with a reference cooler.
For the R9 290:
Sapphire Vapor-X > Sapphire Tri-X > MSI Twin Frozr > PowerColor PCS+ > Gigabyte Windforce >>> Asus DCU2 >>> reference cooler
Club3D, HIS, Diamond, VisionTek, and XFX are all the less desired cards (higher failure rates / worse customer support) -- and I'd avoid them as they usually aren't much cheaper.
