Radiator fans direction
Go to solution Solved by QueenDemetria,
Basically the title. I'm installing a CPU liquid cooler (h105), just wondering which way my fans should be for the cooler (intake or exhaust), I'm putting the fans on the side of my case ceiling closest to my motherboard.
Thanks
Position your fans so that the hot air exits the case, so exhaust.
Thanks
https://linustechtips.com/topic/253518-radiator-fans-direction/#findComment-3473223
Totally, use the fans as exhaust ... next decision is whether to have push or pull configuration, push the air through the rad or suck it through (pull). Linus has recommended pull for the ease of cleaning the radiator.
i5 4670k @4.2ghz / MSI Z87 G45 / EVGA GTX 960 SSC / Samsung  840 EVo SSD / WD Green 1tb HDD / Corsair H75 / Corsair Obsidian 750D / Corsair CS750M
https://linustechtips.com/topic/253518-radiator-fans-direction/#findComment-3473610
