I need help in my C# project and it seems that all of my forms have a problem with the input to my SQL Database. I'm mostly stuck on my record creation and update in windows form.
here's the codes:
            SqlCommand cmdUpdate = new SqlCommand();
            cmdUpdate.Connection = cn;
            cmdUpdate.CommandType = CommandType.Text;
            cmdUpdate.Parameters.Add("@Lastname", SqlDbType.VarChar).Value = txtLastName.Text;
            cmdUpdate.Parameters.Add("@firstname_lastname", SqlDbType.VarChar).Value = txtFirstName.Text;
            cmdUpdate.Parameters.Add("@MI", SqlDbType.VarChar).Value = txtMI.Text;
            cmdUpdate.Parameters.Add("@Addressunknown", SqlDbType.VarChar).Value = txtAddress.Text;
            cmdUpdate.Parameters.Add("@TelNo", SqlDbType.VarChar).Value = txtTelNo.Text;
            cmdUpdate.Parameters.Add("@CustomerBday",SqlDbType.DateTime).Value = dtpBirthdate.Value;
            cmdUpdate.Parameters.Add("@CustomerStatus", SqlDbType.VarChar).Value = cboStatus.SelectedItem.ToString();
            cmdUpdate.Parameters.Add("@Registration",SqlDbType.DateTime).Value =dtpRegistration.Value;
            cmdUpdate.Parameters.Add("@CustomerNo", SqlDbType.Int).Value =int.Parse(txtCustNo.Text); //getting my error in this line
            cmdUpdate.CommandText = "UPDATE Customers2 " +
                " SET Lastname = @Lastname, " +
                " Firstname = @firstname_lastname, " + " MI = @MI, " +
                " Address = @Addressunknown, " + " TelNo = @TelNo, " +
                " CustomerBday = @CustomerBday, " + " CustomerStatus = @CustomerStatus, " +
                " Registration = @Registration, " +
                " CustPicture = @CustPicture " +
                " WHERE (CustomerNo = @CustomerNo)";
            Image bmp;
            System.IO.MemoryStream ms;
            if (picImage.Image== null)
                bmp =Bitmap.FromFile(Application.StartupPath +@"\Anonymous.jpg");
                ms = new System.IO.MemoryStream();
                bmp.Save(ms,System.Drawing.Imaging.ImageFormat.Bmp);
                cmdUpdate.Parameters.Add("@CustPicture",SqlDbType.Image).Value =ms.GetBuffer();
            else if (openFileDialog1.FileName != "")
                bmp =Bitmap.FromFile(openFileDialog1.FileName);
            else
                cmdUpdate.CommandText= "UPDATE Customers2 " +
                    " SET Lastname= @Lastname, "+
                    "Firstname= @firstname_lastname, " +
                    " MI = @MI, " +
                    "TelNo= @TelNo, " +
                    "CustomerBday= @CustomerBday, " +
                    "CustomerStatus= @CustomerStatus, " +
                    " Registration = @Registration " +
                    " WHERE CustomerNo= @CustomerNo";
            cmdUpdate.ExecuteNonQuery();
        //14
        private void DeleteRecord()
            int nPosition = 0;
            if (cm.Count > 0)
                if (MessageBox.Show("Are you sure?", "Confirmation",MessageBoxButtons.YesNo, MessageBoxIcon.Question) == DialogResult.Yes)
                    nPosition = cm.Position;
                    SqlCommand cmdDelete = new SqlCommand();
                    cmdDelete.Connection = cn;
                    cmdDelete.CommandType = CommandType.Text;
                    cmdDelete.Parameters.Add("@CustomerNo",SqlDbType.Int).Value =txtCustNo.Text;
                    cmdDelete.CommandText= "DELETE Customers2 WHERE CustomerNo= @CustomerNo";
                    cmdDelete.ExecuteNonQuery();
                    RemoveDataBinding();
                    GetRecords();
                    AddDataBinding();
                    cm.Position = nPosition;
                    DisplayRecordPosition();
                    DisplayPicture();
                    if (cm.Count <= 0)
                        InitializeNewRecord();
                        txtCustNo.Text = "";
                        txtCustNo.Select();
                        cboStatus.SelectedIndex =-1;
                        cboStatus.Text = "";
                        lblRecordPosition.Text = "Empty";
                    }//end of cm.Count <= 0
                    MessageBox.Show("A record has just been deleted.", "Delete",MessageBoxButtons.OK, MessageBoxIcon.Information);
                else
                    MessageBox.Show("You preferred not to delete this record.", "Delete Cancel", MessageBoxButtons.OK, MessageBoxIcon.Information);
//end of 1st IF
            else
                MessageBox.Show("There is no record available as of this moment.","Empty Table", MessageBoxButtons.OK, MessageBoxIcon.Information);
I'm not sure if I have other errors since I'm really stuck with this one. Any help is highly appreciated.
My Current PC Codename: Scrapper
Intel i5-3570 | Some LGA 1155 MOBO Some Generic DDR3 8GB 1600Mhz | PowerColor RX 560 2GB | Recycled HP Case Crucial MX100 128GB 1TB WD Blue 7200RPM | Some Generic 500w PSU | Intel Stock Cooler
https://linustechtips.com/topic/253516-help-with-c/
what error is it saying exactly? you say you get an error at the line for setting the customer number value but what is the error given?
It occurs when I add a record using my form
https://linustechtips.com/topic/253516-help-with-c/#findComment-3473271
It would be helpful to post what version of the .Net runtime you're using. For example, madknight3 has a good point about using the .TryParse functions, but if you're on .NET < 2.0 then those functions don't exist. If you're using int.Parse() for validation then you're doing that wrong; try using regular expressions as they work well for that task. Lastly, don't store a phone number as a numerical value. It's a string of numbers, like a U.S. zip-code. I'll give you an example of why you won't want to do this. Lets say you're trying to store the number for the US Embassy in China which is 010-8531-4000. An integer will not store the leading 0 so you'll be recording the wrong data.
https://linustechtips.com/topic/253516-help-with-c/#findComment-3507104
Dude... attach a file next time.dont post rough code
It's ok now don't worry xD
https://linustechtips.com/topic/253516-help-with-c/#findComment-3517866
