Around 550W should be a good amount.
Whatcha doing with it?
Better Link: http://www.amazon.com/gp/registry/wishlist/3O6ERAW8ASOCU/ref=cm_sw_su_w
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/253465-how-much-power-do-i-need/#findComment-3472566
gaming
X99 is excessive just for gaming.
Try this, very similar performance, less cost. http://pcpartpicker.com/user/mourningsouls/saved/39KNnQ
Could swap 970 for 980 and 4690 for 4790 and still save.
https://linustechtips.com/topic/253465-how-much-power-do-i-need/#findComment-3472625
-snip-
Are you sure you want an x99 build?
If it's strictly for gaming, we can build you something better for the price.
What's your location and budget?
And welcome to the forums!
#SAMSUNG  "provided us 4 1tb ssds so we could run the whole site off solid state." - LinusTech
#GALAXY
#ATIV
https://linustechtips.com/topic/253465-how-much-power-do-i-need/#findComment-3472638
And welcome to the form
i was looking a x99 build for the fact I don't have upgrade for long time plus want to do 4k gaming, where I'm at Ohio and my budget 2500-3000
and thank you :).
https://linustechtips.com/topic/253465-how-much-power-do-i-need/#findComment-3472660
thank you.
Also, I just took a closer look at that monitor, 4k on a single 970 or even a single 980 won't be amazing. Would recommend 1080p or 1440p. Don't know screens very well though, so I can't recommend you any good ones.
https://linustechtips.com/topic/253465-how-much-power-do-i-need/#findComment-3472667
and thank you :).
If you're looking for 4K gaming, x99 is useless.
An i7-4790K would perform just the same as a x99 build. Linus did a video about this.
x99 builds are only for true diehard enthusiasts or content creators who can benefit from the extra processing power for Premiere and such.
I'll make a build for you really quick but I need the following information
  • Do you need the OS?
  • Is the budget tower only, or do you need the peripherals also?
  • Do you want a color scheme?
  • Any other specific requirements?
#GALAXY
#ATIV
https://linustechtips.com/topic/253465-how-much-power-do-i-need/#findComment-3472675
I see what you're say I'll take look at the video , yes and i'm kind flexible when come to the case but it has be mid tower (small room) maybe some white so I can show off the inside, I like cpu liquid cooling
https://linustechtips.com/topic/253465-how-much-power-do-i-need/#findComment-3472702
I was thinking going with 2 970 if was going stay with 4k monitor. if I just running one I would run a 1440p monitor
https://linustechtips.com/topic/253465-how-much-power-do-i-need/#findComment-3472718
If you're planning on 2 GPU's, then I'd recommend an EVGA 750W or 850W G2.
https://linustechtips.com/topic/253465-how-much-power-do-i-need/#findComment-3472763
I can cut corners if you want it cheaper.
I didn't include the OS, peripherals, or the monitor.
Features/Tips/Configuration:
  • Raid 0 2TB drives
  • Asus 980 Strix in 2 way SLI
  • Corsair H100i for easy water cooling (can be replaced with a NZXT kraken x61)
  • Technically, we can go with a R9 295 X2, but you should ask the forum members if you want that configuration.
PCPartPicker part list: http://pcpartpicker.com/p/9n8trH
Price breakdown by merchant: http://pcpartpicker.com/p/9n8trH/by_merchant/
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($329.97 @ OutletPC)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($79.99 @ Newegg)
Thermal Compound: Arctic Silver 5 High-Density Polysynthetic Silver 3.5g Thermal Paste  ($6.98 @ OutletPC)
Motherboard: Asus Z97-DELUXE(NFC&WLC) ATX LGA1150 Motherboard  ($372.98 @ SuperBiiz)
Memory: G.Skill Sniper Series 16GB (2 x 8GB) DDR3-2400 Memory  ($167.99 @ Newegg)
Storage: Samsung 850 Pro Series 512GB 2.5" Solid State Drive  ($364.99 @ Amazon)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($79.98 @ OutletPC)
Video Card: Asus GeForce GTX 980 4GB STRIX Video Card (2-Way SLI)  ($579.99 @ Amazon)
Case: NZXT Phantom 530 (White) ATX Full Tower Case  ($89.99 @ Newegg)
Power Supply: Corsair CX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($69.99 @ Newegg)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer  ($13.99 @ Newegg)
Case Fan: Noctua NF-F12 PWM 55.0 CFM 120mm  Fan  ($21.99 @ Amazon)
Total: $2882.78
Generated by PCPartPicker 2014-11-19 02:11 EST-0500
#GALAXY
#ATIV
https://linustechtips.com/topic/253465-how-much-power-do-i-need/#findComment-3472780
