Using different res on 4k monitors?
I'm planning on getting a Samsung 4k monitor and was just wondering if I don't have enough GPU horse power for gaming at 4k can I drop the res to like 1440p and will it look good or fuzzy.
PCPP http://pcpartpicker.com/p/Vg96f7 CPU: Intel i7 4790K MoBo: Gigabyte Z97X S.O.C Ram: G.Skill 2x 8gb GPU: 2x AMD R9 290x in CrossFire SoundCard: Creative Sound Blaster z Case: NZXT H440 RED/BLK Storage: 2x Intel 520s 120gb Raid 0 + 2tb Seagate 7200 PSU: EVGA 1000W G2 Fully Modular Display: Samsung UHD 4K 28'' KeyBoard: Corsair K65 RGB Mouse: Cyborg R.A.T 7 Sound: Logitech z506 OS: Windows 10 TP
https://linustechtips.com/topic/253350-using-different-res-on-4k-monitors/
I have a Samsung 4K monitor, and although it's possible it looks pretty fuzzy.... But turning down the settings works just fine for me.
Btw, hope you end up getting one. It's such a great monitor :)
// irenebb-pc v5 // [] Intel i5-9400F [] Radeon VII Lisa Su Edition [] 24GB Crucial Ballistix [] Acer ED323QUR (1440p/144hz) []
I would recommend getting a 1440p monitor then and later getting a 4k monitor and having dual monitors
Planned I Hope Someday I Do First Build: CPU: Intel Core i7 5820k CPU Cooler: CM Hyper 212 EVO Mobo: MSI X99S SLI PLUS RAM: Corsair Vengeance LPX 16GB (4x4GB) DDR4-2133Mhz Storage: Corsair Force LS 240GB SSD & 2TB WD Green Graphics Card: ASUS GTX 970 4GB Turbo Case: NZXT S340 White PSU: EVGA SuperNOVA NEX 750W 80+ OS: Windows 8.1 64-bit OEM Monitor: AOC i2267Fw 60Hz 22" Monitor
It will look fuzzy at 1440p, yes. What are the specs of your pc?
Honestly, if you don't have at least SLI 780 or AMD equivalent (XFire 290), then you shouldn't use 4k for gaming.
In my experience 2560x1440 still looks perfectly sharp on a 4K screen ingame. Anything lower than that is noticeably fuzzier. Mine doesn't support simple scaling though (direct 1-to-4 pixel mapping) so a monitor which can do that should in theory be able to run at 1080p natively, and it would look just like a regular 1080p 28" monitor.
(EDIT: Those of you who say 1440p is fuzzy, I'm curious have you actually seen it or are you just saying it's fuzzy automatically because it's a non-native res?)
I've got a 290x and I'm buying a second soon
