Looking for some help. I have a G600 and for some reason every evening after work when I go to use the mouse, the scroll wheel is always stiff as hell. The only way to fix it is to breath on the wheel to warm it up so it scrolls fine. But then if I leave it alone for 30 mins it gets stiff again. What do I do?
https://linustechtips.com/topic/253349-logitech-g600-problem/
place your mouse in a wool pouch thing so it can stay warm during the cold winter
a mouse is just like you, it needs soft clothes to survive
Gaming Rig: i5-3570k+H100i (4.3 ghz) | P8Z77-i Deluxe | MSI Twin Frozr 7950 Boost | HX650 | 1TB HGST | 840 Evo 250 GB
https://linustechtips.com/topic/253349-logitech-g600-problem/#findComment-3471036
Mine does that sometimes, I usually just give the mouse wheel a very good cleaning.
// irenebb-pc v5 // [] Intel i5-9400F [] Radeon VII Lisa Su Edition [] 24GB Crucial Ballistix [] Acer ED323QUR (1440p/144hz) []
https://linustechtips.com/topic/253349-logitech-g600-problem/#findComment-3471039
where can I get one of those?
The thing is it isn't dirty. I opened it and clean it with some alcohol and it still stiffens up.
https://linustechtips.com/topic/253349-logitech-g600-problem/#findComment-3471079
Ah, try making the LED light pure white. Whenever I use that setting, my mouse gets pretty hot. It may help :)
https://linustechtips.com/topic/253349-logitech-g600-problem/#findComment-3471086
If the LED thing doesn't work, this might suffice http://www.amazon.com/Case-Logic-Universal-Pocket-Red/dp/B002ZZIC62/ref=sr_1_1?s=electronics&ie=UTF8&qid=1416361178&sr=1-1&keywords=knit+bag&pebp=1416361179485
Good luck with your mouse! :)
https://linustechtips.com/topic/253349-logitech-g600-problem/#findComment-3471121
i dont think they even make those. it was mainly a joke but it might work
you can probably ghetto stuff it in a large size glove and it should be fine
https://linustechtips.com/topic/253349-logitech-g600-problem/#findComment-3471126
Does the profile detection work with your mouse.... mine doesn't
https://linustechtips.com/topic/253349-logitech-g600-problem/#findComment-3471147
