hi tech fans. I'm just looking for feedback on it
http://pcpartpicker.com/user/Drummerforlife/saved/yshYcf
all the info is in the note of the site. thanks and continue teching
If you are in US, try going with this instead:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.94 @ OutletPC)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($89.79 @ Newegg)
Memory: G.Skill Sniper 8GB (2 x 4GB) DDR3-1600 Memory  ($79.99 @ Newegg)
Storage: Crucial MX100 128GB 2.5" Solid State Drive  ($69.93 @ Amazon)
Video Card: Gigabyte Radeon R9 290 4GB WINDFORCE Video Card  ($222.00 @ Newegg)
Case: Aerocool Strike-X One ATX Mid Tower Case  ($59.99 @ Amazon)
Total: $860.30
Generated by PCPartPicker 2014-11-18 09:54 EST-0500
You dont really need a CPU Cooler for the i5 4690k if you dont OC or do low level OCing, and that could be added anytime, while the CPU will last you alot longer than a 8320. And I dont have to say anything about the GPU right ^^? Other changes happen mostly because I use a prebuild I have instead of modify yours, but all the part I choose is of good quality.
Else turn it down a little to:
Video Card: MSI Radeon R9 280 3GB TWIN FROZR Video Card  ($190.91 @ Newegg)
Total: $829.21
Generated by PCPartPicker 2014-11-18 09:57 EST-0500
My rig: Intel Core i7 4790k | MSI Z97 PC Mate | GSKILL Ripjaws X 16GB 1866MHz | ADATA Premier SP550 480GB SSD | Seagate Barracuda 3TB | Seagate Barracuda 2TB  | MSI Gaming X GTX 1070 | Thermaltake Versa N21 | Corsair CX550M Semi Modular PSU | AOC G2460PF 144Hz | Logitech G502 | GSKILL Ripjaws KM780  | GAMDIAS HEPHAESTUS V2  PCPartPicker | Old Build Log | New Build Log
https://linustechtips.com/topic/252965-idea-for-future-built/#findComment-3466323
