So I got a new mobo, CPU and memory I set it all up and my DVD drive started smoking.. So I tried plugging in my other one and it wouldn't work so I turned it off and it was really hit at the bottom.. Suggestions??
Can u explain what u mean by it was really hit at the bottom
And did the other one catch fire or just smoke?
https://linustechtips.com/topic/25269-need-help/#findComment-320169
im assuming you said hot...and check to see if you pluged in the power connector wrong or in the wrong spot in your modular psu if you got one...or if you got a molex to sata adapter...if you plugged in the molex cable wrong....that might short out the drive...
https://linustechtips.com/topic/25269-need-help/#findComment-320178
Can you remove one of the 660 ti's and see how the system boots...btw..do not plug in your DVD..just your boot drive..
the computer boots up fine its just when i have the dvd plugged in all it does is blinks green.. the tray wont open and the bottom of it gets really hot
https://linustechtips.com/topic/25269-need-help/#findComment-321242
How do you have it set up..is it SATA with SATA PWR connectors..or do you have it powered by a 4 pin Molex..? It sounds like it maybe either a bad DVD ..or that you have a bad power cable going into it..
Your best effort is the easiest thing to give to someone else..
https://linustechtips.com/topic/25269-need-help/#findComment-322160
yh i agree it sound like a bad DVD drive, if you got a spare computer to create a USB windows OS to use to install windows for now.
https://linustechtips.com/topic/25269-need-help/#findComment-323204
i had  it setup with molex to sata power then i used a sata pwr connector both gave me the same thing..i dont think its a bad DVD cause i bought two and they both did the same thing...
dont have a spare computer on me but ill figure out something maybe borrow a external dvd drive or somehing
https://linustechtips.com/topic/25269-need-help/#findComment-324746
