I am a moderate pc builder. I know what things do and have built at least a dozen PC's for or with friends. Another one of my friends wants to build a pc, so the first thing I asked him was, "What do you want to do with it?"
He wants to play Arma 3 at 1080p and battlefield, but mainly Arma 3. He also is getting into the world of youtube and will end up editing videos. I have no clue if AMD or intel cpu's play arma better and the same between nvidia and AMD.
He cant spend more than $900, but is looking more about $800.
I was thinking AMD 8350 and overclock it with the proper cooling of course.
A R9 280,(he will always add a monitor when he can but for now he only has one)
8 gb of RAM (Later he will upgrade to 16 when he saves the money but for now it will be fine)
And any help would be nice. Like what case has nice cooling. He wants a big case so it will have great airflow and it doesnt really matter what color)
Thanks for any help!
http://pcpartpicker.com/p/hLnVbv
Thats what I have in mind.
https://linustechtips.com/topic/252684-pc-build-need-some-help/
Arma 3 is really poorly optimized, but will run better with Intel's fast cores.  I'd set him up with at least a 4690k if he plans on doing YouTube.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
https://linustechtips.com/topic/252684-pc-build-need-some-help/#findComment-3462018
Link is broken.
My Setup:
Desktop
Main Laptop:
Thinkpad T420:
https://linustechtips.com/topic/252684-pc-build-need-some-help/#findComment-3462020
You say fast cores. So would overclocking be usless. Because I don't think he could fit the i5 into the budget.
https://linustechtips.com/topic/252684-pc-build-need-some-help/#findComment-3462058
Who says that an i5 won't fit the budget???
I present you the under $900 overkill, well just $10 less...
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($179.99 @ SuperBiiz)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($74.78 @ Newegg)
Video Card: Gigabyte GeForce GTX 970 4GB Video Card  ($329.99 @ Amazon)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($64.99 @ Directron)
Total: $890.39
Generated by PCPartPicker 2014-11-17 19:21 EST-0500
Edited by mosin40
https://linustechtips.com/topic/252684-pc-build-need-some-help/#findComment-3462062
An i5 would be better.  Look at the build @mosin40 set up.
My Setup:
Desktop
Main Laptop:
Thinkpad T420:
https://linustechtips.com/topic/252684-pc-build-need-some-help/#findComment-3462176
