yea sure, i would put a 280 rad in the top and a 120 in the back, if you cant put a rad in the back leavef just the 280 in the top but make sure it is a thick rad
you can actually put a triple 360 rad in the top, do that rather
here is the full list from corsair's website:
  • Radiator and fan compatibility compatibility:
    • Top: 3 x 120mm or 2 x 140mm (360mm radiator)
    • Front: 2 x 140mm or 2 x 120mm (2 x 140mm included) (280mm radiator)
    • Bottom: 2 x 120mm (240mm radiator)
    • Rear: 1 x 120mm (120mm included) (120mm radiator)
Are you new to the forums???? read the Code of Conduct HERE WANT SOME AWESOME LTT THEMED WALLPAPERS??? check out XTanksSlayerX's wallpaper thread HERE
"May our framerates be high, and our temperatures low" - PC MasterRace
https://linustechtips.com/topic/252612-450d-water-cooling/#findComment-3461122
From this i will get a 360 rad top and a bottom 240 rad so there is still a hard drive cage for 3 hdd's i guess
https://linustechtips.com/topic/252612-450d-water-cooling/#findComment-3461388
