battlefield 3 frame drops
Go to solution Solved by freexavier,
I have been playing bf3 on pc for a couple weeks now but since yesterday i'm getting frame drops on the lowest settings on 1080p with 70fps average
does somebody know how to solve this?
sorry for bad english
Try disabling In-Game Origin. It is cause of lag and crashing sometimes. Also try Unparking your CPU Cores and get the latest driver for you GPU.
Edit:
Also PC specs would help greatly.
it works for bf4, so maybe try that and see what it does.
"i had similar problems, the only thing i found to fix it, is really simple.
got to your bf4 doc (C:\Program Files (x86)\Origin Games\Battlefield 4) and go to properties of Bf4 and Bf4_86. go to compatibilities and select execute as administrator. do this on both. and i did it for origin too.
didnt had any fps loss after that."
good luck.
may your framerates be high and your temperatures be low. #pcmr
Edit:
Specs: [CPU: Intel i5-4570(Clock to 3.6Ghz)] [GPU: Dual-X R9 270x 2GB] [RAM: x1 HyperX Blu 8GB 1600] [OS: Win8.1]
