It should be working at the same level, unless you have something like an FPS limiter on to reduce load, in which case it will make the system work harder. Not sure what you mean by increase lag, but increasing resolution could decrease framerate.
Desktop: i7-4790k, Samsung 840 EVO 250GB, Seagate Barracuda 3TB, 2xR9 290 Vapor-X's (1 working atm), Asus Z97-Pro, NZXT H440 White, 16GB G. Skill Sniper RAM, NZXT HALE V90 850W.
Laptop: Samsung Chromebook 11.6"
Phone: 8GB Galaxy S4
https://linustechtips.com/topic/252051-lag-question-help/#findComment-3454201
Does playing on a higher resolution increase lag in a FPS game, or will it only make the system work harder to render it?
Playing at higher resolutions make this kind of math "more pixels" = "more work", so yes it makes your system work harder. Why you think Linus had to make a special 4K build guide?
https://linustechtips.com/topic/252051-lag-question-help/#findComment-3454399
