So I am working on a new build for collage and I want to know if all these parts will fit properly into my new case.
The case is the BitFenix Colossus mATX
Here is the build: http://pcpartpicker.com/p/x6F9yc
I am going to recycle the PSU and storage (2.5 drive and 3.5 drive) from my old build.
So the question is, will all of this fit properly, and can I do light 4k gaming on this build?
If you have any suggestions on how to make this cheaper, or if I should use different parts. Please go right ahead and tell me!
Thanks and Cheers~
-Cheers Everybody-
https://linustechtips.com/topic/252019-will-everything-fit-alright/
Everything should fit, and im pretty sure you can do 4k gaming assuming you are going to OC, and if your monitor can go up to that resolution
Yeah included in that build is a 4k monitor. So that should be good to go. What does OC mean? :3
-Cheers Everybody-
overclock, you might not even need to.. but if you do, you should have the option with the z97 board
Runescape player  II  Civ 6 and LoL noob  II
