I want to get a NAS so i can stream my media to all my devices in my house.  I have an old Hadron air case, 2tb WD Green HD and a 4gb stick of ram in my garage taking up space, what i want to know is should i spend $200 and buy a
processor: Pentium G3258 - http://www.newegg.com/Product/Product.aspx?Item=N82E16819117374
motherboard: ECS Z87H3-M - http://www.newegg.com/Product/Product.aspx?Item=N82E16813135377
and a second 2tb hd and use free nas on that build,
or should i just spend $200 and buy something like this Buffalo Linkstation: http://www.amazon.com/gp/product/B00JY4QD4A/ref=s9_simh_gw_p147_d0_i1?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=1GPAYRN10DSH58G15VEF&pf_rd_t=101&pf_rd_p=1688200382&pf_rd_i=507846
Which would give a better experience? and which is worth my $200?
https://linustechtips.com/topic/251984-advice-on-a-nas/
You would get better read write speeds when building your own. UNLESS you spend 500$ on a good off the shelf nas, then the speeds are the same.
CPU: I7-5820k @ 4.7 GHZ
CPU Cooler: Corsair H100I GTX
Motherboard: Asus X99 Sabertooth
Memory: Crucial Ballistix Sport LT 8x8GB (64GB Total)
Storage: 4x 850 EVO 1000GB & 1x 5TB Seagate HDD
PSU: Corsair HX1000i 80+ Platinum
GPU: EVGA Titan X 12GB SLI (2x)
Case: Corsair 400C
OS: Windows 10 Pro
Monitor: ASUS ROG PG279Q 165hz
https://linustechtips.com/topic/251984-advice-on-a-nas/#findComment-3460908
